How to set up the section of comments
1693
7
02-10-2014 03:20 AM
xinlongliu
The 2013 CE has a new section--comments.I want to know how to set up this section.[ATTACH=CONFIG]31282[/ATTACH]
Tags (3)
MatthiasBuehler1
Hi !
When you have a WebScene open, you have a 'Help' link on top in the WebViewer, which takes you here:
http://resources.arcgis.com/en/help/arcgisonline/010q/010q000000nz000000.htm
There, scroll down to 'Comments pane'..
Ok ?
matt
xinlongliu
Hi !
Ok ?
matt
Can i have the section 0f the comments if i published the Web Scene in my Website?
AndreasUlmer
CityEngine Web Viewer comments are only available on 3ws scenes that are stored on ArcGIS Online, or on an installation of Portal for ArcGIS.
xinlongliu
is there possible to set up the comments on the 3ws scenes that are stored on my Website in the future with the help of the CE SDK?
MatthiasBuehler1
The CityEngine SDK is something entirely different > This is not possible.
[ The CityEngine SDK is 'CityEngine's core functionality that generates the models based on a shape and a rule package. ]
Matt
xinlongliu
Matt
yes,i know.If i don't publish the web scene to ArcGIS-Online,how to set up the section of  the comments in the scenes
ElliotHartley
Without significant modification of the webscene offline viewer code you can not accept comments unless you are using ArcGIS online.   SmartBetterCities as far as I am aware have done something on this.
