How to put model on an edge where two faces meet?
2010
03-13-2016 09:43 PM
ChristianShiel1
My house has a gabled roof and I want to add guttering and wooden edging.
I see I can do comp to select but I don't see an option to select between two faces?
I have shown below in the picture the red lines are where I want to attach the models.
I read this part: Help -
But using comp with ridge doesn't seem to work.
ChristianShiel1
Ok I think I maybe got it I have to use comp(e) for edge.
CherylLau
Yes, that is correct.  You have to use comp(e) with the selectors eave, hip, valley, and ridge because these selectors are only designed to work for edges.
Component Split Operation
(See the section on Roof Edges.)
