How to cut perpendicular to the edge?
1282
04-27-2019 06:15 AM
MikeJane
Hi, I couldn't do this like attached example.
   I want to be able to make the cut perpendicular to each side. But when I change the scope according to the edge, it only split selected edge direction. I want to make multiple direction cuts at the same time. How can I do it ?
MatthiasBuehler3
use alignScopeToGeometry() with the according edge index.
e.g.
alignScopeToGeometry(yUp, 0, i)
0 indicates the first polygon of the shape. Typically, a shape only has one polygon, but also can have multiple ...
i indicates the edge of interest.
After this, scope x is oriented along the edge, therefore splitting in z will be perpendicular (assuming you work with flat shapes).
Cheers,
matt
matthias buehler || ceo & co-founder || msc. arch. eth zurich
vrbn AG – official esri partner
|| www.vrbn.io || winterthurerstrasse 53 || 8610 uster || switzerland
+41 78 930 04 07 || matthias.buehler@vrbn.io || @vrbnio @mattb3d
MatthiasBuehler3
e.g.
Cheers,
matt
