How can I split a street to remove the entry and exit?
1253
06-14-2020 07:02 PM
AbeleGiandoso
Hi
Is there a way to use the split operation to remove the entry and exit parts of a street and keep the portion which has the regular street width?
some variation of
split(u, uvSpace, 0)
Here Street and intersection shape UV—ArcGIS CityEngine Resources | Documentation
the docs says that :
 The central region of the geometry is normalized along its length from 0 to 1, and across its width by 0 to the number of lanes.
The entry and exit of a street shape are parameterized to blend with the central region. For example the entry (above, blue) and exit (green) u-values are oriented and scaled to match the central region (red). The entry has negative U values, and the exit has U values greater than 1.
How can I say, "cut everything with UVs which are out of the 0,1 range?
Cheryl Lau, Simon Haegler any idea?
Thanks
A
MatthiasBuehler3
yes, you can do this with the UV split.
One side has negative values in v-coords, so you can use the absolute of that to cut off that part. On the other side, you can cut by the distance of the (max v) - floor(max v) ((or very similar)).
Check the vmin, vmax functions.
Cheers,
matt
matthias buehler | founder & CTO | msc arch eth zurich
MatthiasBuehler3
Cheers,
matt
