how can i attach every floor number returned by split.index to a database with floor attributes?
3708
09-08-2014 01:19 AM
johne
I want to view the attributes of each floor number returned by split. index when I export it to a webscene but i dont know how to write that rule. so that if if index is one it diplays attributes in a database relevant to a floor with index one.
In the same case. is there any waty to report a string instead of numbers only?
by Anonymous User
Not applicable
You can use CGA string functions to make database-like lookup functions. One of the ESRI.lib rules, Plant_Loader, has an example of this. The plant data came from an Excel spreadsheet. The data was formatted as CGA using Excel string functions. It will take you a bit of studying to understand it, but it is a useful technique. Hope this helps!
by Anonymous User
Not applicable
You can report strings, but there is no support for this other than Python-based export. See this thread for more explanation: Web Scene Attribute numbers
DavidWasserman
This link might be helpful in terms of providing documentation on script based exports.
http://cehelp.esri.com/help/index.jsp?topic=/com.procedural.cityengine.help/html/manual/python/pytho...
David Wasserman, AICP
johne
thanks guys.
