Global Texture Projection Error
1167
11-10-2012 01:01 AM
ziadfilfili
Hello,
I am trying to trim the texture and apply it as a roof texture on the buildings.
it worked, but for some reason the mapping of the texture is different,
I attached an image with a red outline to show where its taking the texture from and applying it on the building.
And a purple outlined to show the rule.
i CAN'T know what seems to be the problem...
Cheers,
MatthiasBuehler1
Try this code .. 🙂
satelliteImage = "builtin:uvtest.png" #"maps/mySatellitePic.jpg" # user defined image in maps folder
satelliteImageData(data) =
 case data == "SX"   : 1000    # user defined, same as terrain extent. select terrain layer and check Inspector
 case data == "SZ"   : 1000
 case data == "OX"   : 1000
 case data == "OZ"   : -1000
 else : 1
Roof -->
setupProjection(0,world.xz,satelliteImageData("SX"), -satelliteImageData("SZ"), satelliteImageData("OX"), satelliteImageData("OZ"))
projectUV(0)
texture(satelliteImage)
