FileGeodatabase polygon import error
4371
09-10-2015 02:47 PM
TessOldemeyer
I keep running into the following error when trying to import polygons into CE 2015.1:
'The combined extent of the existing scene and the selected layers is too large: [1905.2194, 2139370.5, 1209.4117]'
The polygons are in the same coordinate system as the scene (NAD83 UTM Zone 12N) and well within the scene extent. Any suggestions?
Thanks!
AneteFridrihsone
Hello,
I have the same problem. Did you find a fix for it?
ThomasFuchs
Hello Anete,
What is the exact error message you receive?
In the message above "[1905.2194, 2139370.5, 1209.4117]" hints, that the problem is in the y-direction (this means up in the CityEngine native coordinate system).
Did you try to import the FileGeodataBase into an empty CityEngine scene? Is the error then still occurring?
