Exporting Data from City Engine into ArcGIS Pro's Attribute Table
1372
10-16-2023 01:23 AM
Richie5678
Hello! I have created a artificial city using the rules files provided in the ESRI Library, but now I need to present some data about the city. I have exported the 3D Models into ESRI GDB, however i realized that the building height that I edited in the rule files are not reflected in the object attributes, thus it does not show up in the attribute table in ArcGIS Pro.
Is there a way I can make a new object attribute to read the building heights for city I made or a way for me to export the building height out to add into the attribute table in ArcGIS Pro
JonasObertuefer
Hi @Richie5678,
Yes this is possible using cga reports in combination with a script based export (python). There is an example you can adapt in this thread:
General ressources about script based export:
Hope this helps,
Best
Jonas
