Embed a youtube video in WebScene
6638
12
09-23-2014 12:02 AM
IonutAlixandroae
Hello,
I have a question regarding embed a youtube video into WebScene. I have some points that have a text type attribute field populated with youtube URL`s.
When in WebScene I click one of those points, in the right part appears the attributes (see print attached). After I click the URL from the point selected, a new tab will appear redirecting to Youtube due to URL. What I want is to appear the video intro the WebScene and not to open a new tab to Youtube.
Is that possible? Can you help me with this? I need to do this in 24-30 hours...
Thank you !!!
johne
yeah its possible to.Instead of writing the url as just an attribute. Iframe it within the information tab. But wat i cant seem to make the video do is play full screen.
Make an object attribute in city engine with one model clicked.
Give it a name and make sure the type is STR
Then for the value input a code like this one.
<iframe width="560" height="315" src="http://www.youtube.com/embed/jofNR_WkoCE" allowfullscreen></iframe>
IonutAlixandroae
Yes this is it !! Another option what I did was changing the attribute in ArcMap. Instead of URL I copied the embed text. I will test this right now.
Thanks you very much !!
johne
You are most welcome. I viewed your web-scene and saw a very nice soccer stadium and animated water.Could you give me pointers on doing the same since i cant get exactly how to animate water.
IonutAlixandroae
That was another scene, the question was for the one I work now, but thank you very much !
Well, the soccer stadium was a .dae file and for the water I imported a vector polygon, and for having that water effect just add "__water" to the name in city engine and export it. The WebViewer automatically does that texture in browser when having that part of the name added. For example having a polygon type for Atlantic Ocean-> add underscore underscore water (Atlantic Ocean__water) and export it.
Thanks !
johne
Thank!
johne
for better placement follow this link
https://community.esri.com/message/350840#350840
IonutAlixandroae
I want to simulate a flooding in a town and I have some points symbolized as push-pins . When I click the one of the push-pin I want in the information area( in the right, with green color) to appear to video that shows the flood from that place. I embed the video but the videos are half sized. I attached a print . Any suggestion? Thanks !!
johne
change value of width to 286 and for height to 333.I you extend that the webviewer slices the extra pixels
IonutAlixandroae
Do you know if there can be added a rain effect in the scene?
Thanks !
