Does CityEngine benefit from using 2 GPU Nvidia GEForce GTX 970 in SLI ?
10732
16
12-17-2014 01:28 AM
IonutAlixandroae
I`m having trouble rendering a scene in CityEngine because of a large consumption on RAM and GPU. ( I`m having like 2000 polygons that I want to apply a rule to create random 9 types of 3D buildings created in Maya) and I want to know if another GPU Nvidia GEForce GTX 970 to be used in SLI and doubling RAM memory to 32 GB would be a solution? Does CE works,support,benefits with 2 GPUs on SLI?
Ionut
Tags (3)
MatthiasBuehler
Well,
Before buying new hardware, I'd strongly optimize what you are working with.
- Terrain Subdivisions
- Create streets with less segment precision and curb-subdivisions
- DON'T use the highLOD (there's not need to see all polys, right ?). // use smart texturing instead of geometric details!
70 million polygons for a GIS project is just way too much !
You'll be easily able to reduce that dataset to a third of the size ..
Ok ?
matt
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
[email protected]
www.garsdaledesign.co.uk
IonutAlixandroae
HI Matt,
Well, I`ll have to ask you to , please,  how to create terrain subdivisions and to create streets with less segment precision and curb-subdivisions( I`m not sure I understand what this means...)
For the building detail I could replace geometries of doors, windows etc with textures but the final result of this product I think will be integration with LumenRT and a movie/animation of the scene....( so for this purpose I need high LOD buildings - I have some key-buildings for this town that I`ve done separately in Maya)
I only need to be able to export export the terrain, buildings and roads from CE to LumenRT and the rest will be done in Lumen...
I`m open for new suggestions
Thanks!!
Ionut
MatthiasBuehler
As always, please consult the help first....
Terrain‌‌
Streets
Additionally, in CGA, did you delete e.g. all bottom faces of extruded shapes where you do not see the bottom polygon?
Before creating such a massive dataset, did you test if LumenRT can even process 10 or 20 million polygons?
Hope this gives some pointers ..
Matt
Matthias Buehler
twitter: @MattB3D
[email protected]
IonutAlixandroae
Regarding deleting the bottom faces in cga , I didn`t ( in the rule i didn`t mentioned the bottom face - so how could I delete it?)
And in Lumen, at the moment, I have a trial for LumenRT 2015 Geodesign and I only imported the terrain with texture and the streets...I will try also tomorrow for buildings import but the first step will be to export them, if possible...
Thank you very much !
MatthiasBuehler
again, manual:
Component Split Operation
Matthias Buehler
twitter: @MattB3D
+44 (0) 15396 20875
[email protected]
DavidBurdick
Hi Ionut,
Matt is right.  LumenRT (or any real time rendering system) will not handle 70 million polys  A typical large scene might be 15 - 20 million polys or less.  I've don a few scene with 50 million polys but it was slow.
zhongrenGu
aha,agree
