Does CityEngine benefit from using 2 GPU Nvidia GEForce GTX 970 in SLI ?
10731
16
12-17-2014 01:28 AM
IonutAlixandroae
I`m having trouble rendering a scene in CityEngine because of a large consumption on RAM and GPU. ( I`m having like 2000 polygons that I want to apply a rule to create random 9 types of 3D buildings created in Maya) and I want to know if another GPU Nvidia GEForce GTX 970 to be used in SLI and doubling RAM memory to 32 GB would be a solution? Does CE works,support,benefits with 2 GPUs on SLI?
Ionut
Tags (3)
by Anonymous User
Not applicable
Have you adjusted the reserved java memory in the CityEngine.ini file? You see this memory shown in the lower right corner of the CityEngine GUI.  If not, I'll explain.
By default this number is around 4GB.
IonutAlixandroae
Hi Chris,
No I haven`t....
I`m not at work right now but as far as I remember the memory you highlighted was around 4000 mb and the one to the left of it around 12000 mb. When I start applying the rules the memory from the right( the one you have 24 gb in the picture above) starts to decrease to around 1000 mb.... I will check again for sure tomorrow morning...
The thing is that we acquired a PC with the GPU specifications from above and 16 GB RAM memory and I`m still having trouble with my scene.... I get to move in it with 2 FPS after I raise all my buildings, terrain and streets...
I want to know for sure if I should double the RAM memory and get another GPU to use in SLI with the other one..
Thanks !
IonutAlixandroae
Hi Chris,
So regarding SLI, does it work ?
Thanks!
MatthiasBuehler
Hey ..
Regarding SLI:
See my reply here:
Re: Freeing up system memory?
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
[email protected]
www.garsdaledesign.co.uk
IonutAlixandroae
Hi Matt,
I understand what you say but the problem is that currently the scene that I`m working on is rendering very slow ( 2-3 FPS) because of big amount of 3D buildings generated ( mostly of them are created in SU and Maya ) ... that`s why I think I need more RAM and GPU ....
BenLeslie1
Hi Chris
Can you explain what to change - I've found the .ini file but it's not obvious to me what to change.
Do you think changing this memory help me?  I've been having some small performance gripes as per this thread.
Re: CityEngine performance expectations?
MatthiasBuehler
Hi Ben,
Sadly, all the old forum entries not easily found anymore. I wrote this all down years ago.
You ONLY edit line 8, "-Xmx"
Nothing else. Watch out that the value in MegaBytes is about max. half your system memory size.
You need more precise details ?
Matt
Matthias Buehler
twitter: @MattB3D
[email protected]
MatthiasBuehler
Guys, please don't mix topics in a thread... !
Ionut, can you post a few a screenshot of how many polygons your rule creates ?
And the polycount.
Please let me know.
Matt
Matthias Buehler
twitter: @MattB3D
[email protected]
IonutAlixandroae
HI Matt,
When I enter my scene and I get the question if I want my models to be re-generated the number is 12649
I have several rules that I have applied - some of them creates 3D buildings from rule ( and also includes obj windows, chimneys and doors) and others just import some 3D buildings created in SketchUp and Maya.
The LOD is high...
Here`s a print of the scene ( it`s an entire city in a mountain area) : 25349 Objects | 71613662 Polygons
