Create simple stairs with CGA
6419
10
11-03-2015 10:29 AM
TessOldemeyer
What is the best route to take in order to connect building floors using stairs as in the ESRI Campus example web scene (http://www.arcgis.com/apps/CEWebViewer/viewer.html?3dWebScene=9c0e319bfaff4d33a0fe2da97c2c3fd7 )? I am unsure of how to best approach this....
I currently have floor layers that have attributes distinguishing stairwells. My floors have been added from file geodatabases and the height offset has been manually set while aligning to terrain.
Any advice or suggestions would be super helpful! Thanks!
Tess
by Anonymous User
Not applicable
Attached is a rule that makes stairs. It was used in the Atlanta airport demo at UC 2015, so there may be some code that was specific to how that was setup. You'll have to study it some. I wrote it, but I don't remember exactly how the directional logic works. You'll have to figure that part out through experimentation.
Chris
by Anonymous User
Not applicable
Chris
ValerioBozzo
Thank you Chris. Very useful
TessOldemeyer
This is super helpful. Thank you very much!
ValerioBozzo
Please, someone can explain how to use it? I tried to apply to shape object but it doesn't work!
I tried to apply to a sloped street, but nothing. Please, help me, I need to transform a sloped street to a flight of steps!
TessOldemeyer
Hmm it worked perfectly for me...I just added in color and transparency
ValerioBozzo
Can you explain me how to do it please?
TessOldemeyer
I just applied the rule to planar sections in stairwells of my floor space.
Here is the rule:
version "2015.1"
attr StairColor="#8b8682"
attr StairTransparency= 0.3
attr LandingColor="#8b8682"
attr LandingTransparency= 0.3
attr landingWidth = 1.2
attr stairDepth = 0.3
attr landingSlabThickness = 0.2
attr stairThickness = landingSlabThickness
@Range("CW","CCW")
attr TransitionDirection = "CW"
attr TransitionHeight = uFeet(13)
const transitionHeight = meters(TransitionHeight)
attr TransitionOrientation = 0 # Using North=0, CW compass, East=90
@Group("Units",6)
@Order(1)
@Range("Feet","Meters")
attr units = "Feet"
unitScale = case units == "Feet": 3.28084 else: 1
const halfFloorHeight = transitionHeight / 2
@StartRule
StairMaster -->
  # Make flat and aligned to world Y axis.
  alignScopeToAxes(y)
  s('1,0,'1)
  # Remove extra vertices.
  cleanupGeometry(all,0.5)
  # Get the inner rectangle, since original shapes might be out of square.
  innerRect
  # Align X axis on longer side.
  # XX Will need to add rotation code.
  PutScopeXGoingLongways
PutScopeXGoingLongways -->
  case scope.sz > scope.sx:
  rotateScope(0,90,0)
  OrientationCheck
  else:
  OrientationCheck
OrientationCheck -->
  # Tilt up end and check which side the landing is oriented, based on the shape.
  rotate(rel,scope,0,0,90)
  set(InitialLandingSide, compassDirection)
  #print("compassDirection"+compassDirection)
  #print("TransitionOrientation "+TransitionOrientation)
  rotate(rel,scope,0,0,-90)
  FlipDirectionMaybe
@Hidden
attr InitialLandingSide = ""
compassDirection =
  case geometry.isOriented(world.north): "N"
  case geometry.isOriented(world.east): "E"
  case geometry.isOriented(world.south): "S"
  case geometry.isOriented(world.west): "W"
  else: "X"
FlipDirectionMaybe -->
  case InitialLandingSide == "N":
  case TransitionOrientation == 0:
  Make270Stairs
  case TransitionOrientation == 180:
  rotateScope(0,180,0)
  Make270Stairs
  else:
  print("Error in TransitionOrientation attribute.")
  color(1,0,0) Error.
  case InitialLandingSide == "S":
  Make270Stairs
  Make270Stairs
  else:
  color(1,0,0) Error.
  case InitialLandingSide == "E":
  case TransitionOrientation == 90:
  Make270Stairs
  case TransitionOrientation == 270:
  Make270Stairs
  else:
  color(1,0,0) Error.
  case InitialLandingSide == "W":
  Make270Stairs
  Make270Stairs
  else:
  color(1,0,0) Error.
  else:
  print("Error in TransitionOrientation attribute - compass error.")
  print("InitialLandingSide = " + InitialLandingSide)
  color(1,0,0) Error.
Make270Stairs -->
  split(x) {
  landingWidth: LandingLowerAndUpper |
  ~1: TwoStraightRuns |
  landingWidth: LandingMiddle
LandingLowerAndUpper -->
  Landing
  t(0,transitionHeight,0)
  Landing
LandingMiddle -->
  t(0,halfFloorHeight,0)
  Landing
Landing -->
  extrude(-landingSlabThickness)
  color(LandingColor)
  set(material.opacity, 1-LandingTransparency)
@Hidden
attr runLength = 0
TwoStraightRuns -->
  set(runLength, scope.sx)
  DJScratchDirection
DJScratchDirection -->
  case TransitionDirection == "CW":
  split(z){'0.5: FirstRun | '0.5: SecondRun }
  else:
  split(z){'0.5: SecondRun | '0.5: FirstRun }
FirstRun -->
  StraightRun
SecondRun --> NIL
  t(0, halfFloorHeight, 0)
  StraightRun
StraightRun -->
  split(x){adjustedStairDepth: Stair}*
Stair -->
  t(0,stairRise * (split.index + 1),0)
  extrude(-stairThickness)
  color(StairColor)
  set(material.opacity, 1-StairTransparency)
adjustedStairDepth = runLength / stairCount
stairCount = rint(runLength / stairDepth)
stairRise = halfFloorHeight / (stairCount + 1)
# Include this in the rule anywhere. Bottom of rule probably.
meters(valueInEitherFeetOrMeters) =
  case units == "Feet": valueInEitherFeetOrMeters * 0.3048
  else: valueInEitherFeetOrMeters
# Allows CGA author to specify defaults in feet, rather than meters times scale.
uFeet(valueInFeet) =
  case units == "Feet": valueInFeet
  else: valueInFeet * 0.3048
uMeters(valueInMeters) =
  case units == "Feet": valueInMeters * 3.28084
  else: valueInMeters
by Anonymous User
Not applicable
I'm sorry Valerio, the rule is not intended for sloped streets. It runs on flat rectangular shapes. You can adjust the slope in the Inspector for the rule.
Chris
TessOldemeyer
I have combined the stairs rule with a floor plan rule in hopes of  being able to use the 'floor plan' portion except in the case where the room type is specified as a stairwell in the attributes. The rule works for either the stairs or the floor plan, but I cannot get both to generate at once. CityEngine has automatically assumed two start rules for the rule file (AddOutline and StairMaster). AddOutline is associated with coloring the floors and generating walls and StairMaster (surprise surprise) is for the stairs. When AddOutline is specified as the start rule, the areas where RM_TYPE=STAIR are left empty. When StairMaster is used as the start rule, the stairs are generated but nothing else.
How can I get the floor plan and stair shapes to generate simultaneously?
Thanks again for all of your help!
Tess
Here is the rule I have so far:
version "2015.1"
#attr Fill_Color = "#FFF80"
attr Outline_Color = "#000000"
@Range(0,1)
attr Transparency = 0.1
attr BorderThickness = 0.2
attr Extrude_Height = 1
attr DV_LTR = ""   # This will connect to your object attribute from the GDB.
AddOutline -->
  offset( -BorderThickness)
  comp(f){border: BorderColor | inside: FillColor}
BorderColor -->
  color(Outline_Color)
  set(material.opacity, 1-Transparency)
  extrude( Extrude_Height)
FillColor -->
     color(getColorFromOrg(DV_LTR)) # This calls the function below using attribute.
  # Expand this function using orgs, with colors in "hex color" format:
  getColorFromOrg(DV_LTR)=
     case DV_LTR == "A" : "#baff1e"
     case DV_LTR == "B" : "#0b5394"
     case DV_LTR == "C" : "#0000ff"
     case DV_LTR == "D" : "#c62104"
     case DV_LTR == "E" : "#ddf1ff"
     else: "#000000"
attr RM_TYPE = ""
@Range("CW","CCW")
@Group("Units",6)
@Order(1)
attr units = "Feet"
StairMaster -->
  case RM_TYPE == "STAIR":
  alignScopeToAxes(y)
  s('1,0,'1)
  innerRect
  else: NIL
  rotateScope(0,90,0)
  OrientationCheck
  else:
  OrientationCheck
  else: NIL
  FlipDirectionMaybe
  else: NIL
  @Hidden
  compassDirection =
  else: "X"
  Make270Stairs
  Make270Stairs
  else:
  color(1,0,0) Error.
  Make270Stairs
  Make270Stairs
  else:
  color(1,0,0) Error.
  Make270Stairs
  Make270Stairs
  else:
  color(1,0,0) Error.
  Make270Stairs
  Make270Stairs
  else:
  color(1,0,0) Error.
  else:
  color(1,0,0) Error.
  else:NIL
Make270Stairs -->
  split(x) {
  else:NIL
  Landing
  Landing
  else:NIL
LandingMiddle -->
  Landing
  else:NIL
Landing -->
  color(LandingColor)
  else:NIL
  @Hidden
  attr runLength = 0
TwoStraightRuns -->
  DJScratchDirection
  else:NIL
  else:
  else:NIL
FirstRun -->
  StraightRun
  else:NIL
SecondRun --> NIL
  #case RM_TYPE == "STAIR":
  StraightRun
  #else: NIL
StraightRun -->
  else: NIL
Stair -->
  color(StairColor)
  else: NIL
  else: valueInMeters
