Corner lot test not working
5954
7
05-05-2015 08:32 AM
curtedmonds
imports fail to load
reports "no such function" : ? streetWidth()
file Colors.cga contains:
SNOW -->color("#FFFAFA")
real bummer if this is the case, as you cant test a corner lots if you have imports
this code was the default example to test corners, WHY this is not a standard "geometry.isCorner" is beyond me...
version "2014.0"
import col  : "Colors.cga"  <<<<< error "no such function" : ? streetWidth()
#BuildingVariables
attr    BldMasterHeightMin = 10
attr    BldMasterHeightMax = 30
attr BldIsCorner =  false
attr streetWidth(i) =  0  <<<<<the offending line needed for index Recursion
Lot-->
    CornerRecursion(geometry.nVertices - 1, 0)
CornerRecursion ( edgeID, nStreetEdges ) -->
    case edgeID >= 0 :
        case streetWidth(edgeID) > 0 :
            #print (edgeID)
            CornerRecursion ( edgeID - 1, nStreetEdges + 1 )
        else:
            #print (edgeID)
            CornerRecursion ( edgeID - 1, nStreetEdges )
    else:
        case nStreetEdges >= 2 :
            #set(BldIsCorner, true)
            doLot #corner Lot
        else:
            #set(BldIsCorner, false)
            doLot #Not corner lot
doLot-->
    extrude(rand(BldMasterHeightMin, BldMasterHeightMax))
    comp(f) { top: doTop | all: doFacard }
doTop-->
    roofHip(20)
    col.PINK
doFacard-->
    col.PINK
by Anonymous User
Not applicable
I was wrong. This code does work. It is StartRules that cannot have parameters, not attributes.
So I tested it and it seems to work in version 2014.1 and 2015.0.
I am glad to see this, because I did not know about it.
Chris
by Anonymous User
Not applicable
Can you rephrase this as a question? I'm not sure what you are saying/asking.
Chris
curtedmonds
Sure.
normally the recursive test "CornerRecursion ( edgeID, nStreetEdges ) -->" should function correctly
However (in testing 2014) the same method for testing a corner Lot produces a strange error when the import function is also used.
I have included  the recursion test source code and where the error occurs
My question is: has the structure or method for testing a corner lot changed? and if not
why does attr streetWidth(i) =  0 produce an error when simultaneously using an import function
I have tried stripping out the import of source code and still be exists, it is only when I don't use import or don't  use the function attr streetWidth(i) =  0.
Has anyone else had experience in "2014" when testing for a  corner lot with this problem or is there a new solution.
perhaps the heading should have said:
import function producers an error...when using attr streetWidth(i) =  0 function. to test corner lots
Hope that helps clarify the issue
Cheers
C
by Anonymous User
Not applicable
The problem is here:
Attributes can not be parameterized in CGA. The import has nothing to do with it.
Where did you find this strange code?
curtedmonds
lol, nice Chris.
I know this is causing the failure, but what then is the the solution to test for a corner lot?
or
an alternative to this usage..
see Re: How to test whether a lot is on a corner?
this also has attr streetWidth(i) =  0
cheers
by Anonymous User
Not applicable
Chris
by Anonymous User
Not applicable
Also, it does not work in 2013 or 2014.0. I think that was a feature that got pulled for a few versions. Not sure. So definitely upgrade to version 2015. It has other improvements...
curtedmonds
k, good to know .
As doubting ones sanity is only fun at parties
thanks
C
