CityEngine
4487
07-16-2014 09:08 PM
jarrygoidon1
Hi There, Somebody please help as I won't be able to use CityEngine 2014 30 days free trial. I Manage to install it but failed to start due to "License server system does not support this feature". I was wondering if someone can explain this to me.
Niels_van_der_Vaart
Did you choose for CityEngine Advanced Single Use in the ArcGIS Administrator. The CityEngine trial comes with a single use license, and therefore no license server is requires.
jarrygoidon1
Yes, I did followed the installation instructions carefully and yes I chooses the CityEngine Advanced Single Use in the ArcGIS Administrator during the installation process. I am actually use my company laptop and inside this laptop there is licensed Arcgis software installed which a server need to be connected in order for me to use this software. I am afraid that this may effect the installation process.
jarrygoidon1
Niels_van_der_Vaart
Jarry, I would advise you to reach out to your local Esri support department. They can help you to sort out the issue.
