CityEngine codes
6631
01-23-2015 04:09 AM
saffetkilicer
I need to some code how the cityengine rules works.
Is there a website like developer user guide or open source library?
Where can I find the cityengine library or CGA scripts including their codes?
Is anyone give me a link, please.
DavidWasserman
The ESRI Lib comes with CItyEngine 2014. It should be on your computer.
CityEngine 2014.0 released! | ArcGIS Blog
David Wasserman, AICP
MichaelWalton
To learn the basics read through this manual...will take about 2 weeks of dedicated time to become familiar with the language used for CE. In geonet, you can search for example rule packages and make sure you complete all the tutorials Matthias made for us.
Help -
DavidWasserman
Hi Saffet,
There was a previous discussion on this topic.
Re: Is there a repository or database of rule files that are available to be downloaded?
If you want to see some great lot rules to look at check out the ArcGIS 3D resource center and look through the ESRI.lib that comes with CityEngine.
The 3D GIS resource center has a number of projects which includes rule files, assets, and other procedural examples. The most common set of rules that we like to share with people include the Redland's Example and others found on the website.
If you are interested in streets, there is a new Complete Streets Example that shows how street rules can be constructed.
David
saffetkilicer
Hi David, can you give a website adress for ESRI.lib, please.
DavidWasserman
