City Engine SDK - Logging
1323
08-07-2018 08:51 AM
BernhardRainer1
Hello,
I'm playing around with the SDK to create a custom exporter. I started with the example plugins and they do work.
However, I'm not able to create a functionaing Logger to print to the console/Log window. I'm using the same code as presented in Esri Procedural Runtime: prtx::LogFormatter Class Reference
auto lh = prt::ConsoleLogHandler::create(prt::ConsoleLogHandler::ALL, prt::ConsoleLogHandler::ALL_COUNT);
prt::addLogHandler(Log);
log_debug("Encoder");
Can anyone point me in the right direction?
Cheers!
SimonHaegler
sorry for the very late response. Is this still an issue for you?
In your code snippet, you probably wanted to write prt::addLogHandler(lh), right?
Best,
Simon
BernhardRainer1
Sorry I haven't logged in into the forum as I found a work-around for my problem. I've got it working for now!
Thanks!
