City Engine and Network Analyst
4651
7
09-11-2014 04:36 AM
IonutAlixandroae
Hello,
I have a question: can I use symbology ( like in ArcMap) -> graduated colors for some routes in City Engine?
Actually, I need to represent some parts of some routes with a color depending on their attributes.
Also, I need more information about using network analyst in CE?
Thanks !
MatthiasBuehler
attr congestion = 0
Sidewalk -->
     Street
Street-->
     case congestion >= 6:
          color(0,1,0)
     case congestion >= 3:
          color(1,1,0)
     else:
          color(1,0,0)
NOTES:
  • don't use string (""), use float (0) when initializing the attr
  • check the name (case sensitivity) of the attr
  • check the attr souce in the Inspector's attr source editor (point to the object attr)
  • Use more StartRules that point to the 'Street' rule
Ok ?
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
+44 (0) 15396 20875
[email protected]
www.garsdaledesign.co.uk
MatthiasBuehler
What is the data you are trying to represent in colors?
CityEngine can not run network analyst. For this, you'd have to export the street segments as polyline features to ArcGIS, then do the network analysis there. Note that the current graph exporter only supports linear street center lines, not curved ones.
Matthias Buehler
twitter: @MattB3D
+44 (0) 15396 20875
[email protected]
IonutAlixandroae
HI,
I saw this : CityEngine Feature: Street Sketching & Network Analysis - YouTube and I want to know how are those streets in multipe colors?
I have some streets and in the attribute table there is a field that represent the congestion . I want to represent them in gradient colors ( like in the picture I attached from ArcMap).
It is possible to use in CE that specific attribute field to practically simbolize my streets with different colors?
Thanks !!
MatthiasBuehler
Hi again,
Yes, the network analysis within CityEngine is a cool thing. The tool calculates the 'integration' value and stores this information as object attributes, then assigns the a rule that does that color-coding.
If you have GIS data, the workflow would be very similar: When you import GIS data (streets) with attributes, the GIS attributes are also imported and inherited to the dynamic street shapes.
You then can create a rule to colorize each shape based on your attribute.
I assume you don't have a lot experience in CGA yet, right ?
Hope this helped a bit so far ?
Cheers !
Matt
Matthias Buehler
twitter: @MattB3D
+44 (0) 15396 20875
[email protected]
IonutAlixandroae
Yes, you`re right. I only managed to create a few buildings and houses on my own imaginations and with some textures from the city I wanted to look alike.
So, that field has numeric values , and I`m thinking of creating a rule where I should involve 3 colors and depending of that congestion values is bigger that "a-value" or smaller than "a-value" it will get a color. And this rule will apply again for one of the 3 colors right?
e.g. - red is for value between 1-3
     blue for value between 4-6
     green for value between 6-10
Am I right?
Thanks!
IonutAlixandroae
So I decided that I want to color my routes with 3 colors : green, yellow and red depending of the value of congestion. The field type is double
So here is something I tried but I keep getting errors:
# color declarations
red = "#ffaaaa"
green = "#aaffaa"
yellow = "#ffff73"
attr Congestion = ""
colorCongestion -->
  case Congestion == range(1, 1.18) : green (for values between 1 and 1.18 the color is green)
  case Congestion == range(1.18, 1.28) : yellow (for values between 1.18 and 1.28 the color is yellow)
  else : red ( for any other values the color is red)
Can you help me please?
Thanks!!
MatthiasBuehler
attr congestion = 0
Sidewalk -->
     Street
Street-->
          color(0,1,0)
          color(1,1,0)
     else:
          color(1,0,0)
NOTES:
Ok ?
Matthias Buehler
twitter: @MattB3D
+44 (0) 15396 20875
[email protected]
IonutAlixandroae
Thanks!!
