Bringing in Polylines as Shapes
2253
07-27-2023 11:12 AM
MattOlsen
Hi everyone.
I'm looking for a workflow to import closed Polylines in AutoCAD as shapes in CityEngine.
I found this video, in which shapes from Sketchup are imported into CityEngine using the KMZ format. When I try to do the same thing, the shapes come in as highly triangulated models. When I use 'Convert Models to Shapes' they merge together.
Has anyone found a clean way to do this?
https://www.youtube.com/watch?v=Plncupf4FA8&t=963s
The power of today's 3D technology is within reach of every planner and designer - helping to shape better policies and decisions around the world. This session takes a deep dive into planning workflows that integrate SketchUp and CityEngine so that you can model and better understand your city in
DevinLavigne
Matt what exactly are you looking to do? What are the lines for? Will they create a fill/shape?
DevinLavigne
@MattOlsen just checking in - your screenshot is my work FYI
MattOlsen
@DevinLavigne
Thanks for following up on this. As you suggested, I wanted a shape that I can assign CGA rules to in the same way as a Lot.
In the end, I found a solution - by creating a HATCH from the shapes, converting to a surface (CONVTOSURF), then converting to a mesh (MESHSMOOTH) - saving a DWG and importing into CityEngine.
DevinLavigne
Sounds good. Yes I was going to say bring them in as fills.
