Batch export of many building models, using one model file per building
6799
15
08-21-2012 11:52 AM
AndrewBasile
When I export a selection of multiple modeled buildings to Wavefront OBJ or Collada DAE format, all of the buildings get lumped together into a single OBJ or DAE.
For our application, we would like to be able to export a large number of buildings at once, and use a separate OBJ or DAE for each building model.  Is this possible in CityEngine?  We do not want to have to manually select and export the buildings one at a time.
DanielBraun2
I tried it with a fresh installation of CE 2013 and the default preset.
Same problem. Only one Material file with only the materials of one object. Looks like a bug in CityEngine.
MatthiasBuehler1
I'm on medical leave and thus cannot look into this this week.
Meanwhile, can you confirm that the 'file size' option works correctly ?
Matt
DanielBraun2
Same problem here:
If I choose the filse size big enough (=> only one OBJ file is generated), everything is fine. If I choose the file size smaller and the model gets splitted into multiplte OBJ files, only one material file (that does not contain all information) is generated.
MatthiasBuehler1
Can you please create a very simple minimal repro dataset with no textures that you can send me to reproduce here ?
E.g. a simple scene with many copied shapes and many boxes stacked on top of each other in CGA
Would that be possible ?
Lemme know ..
matt
DanielBraun2
I've attached a minimal example:
Rule-File:
attr myColor = 50%: "#ff7777"
               else: "#58FA58"
Lot  --> extrude(10) color(myColor)
Material-File with filesize option:
newmtl Lot_1
    Kd 0.345098 0.980392 0.345098
    Ka 0 0 0
     d 1
    Tf 1.0 1.0 1.0
    Ni 1.0
 illum 3
    Ks 0 0 0
    Ns 0
newmtl Lot
    Kd 1 0.466667 0.466667
    Ka 0 0 0
     d 1
    Tf 1.0 1.0 1.0
    Ni 1.0
 illum 3
    Ks 0 0 0
    Ns 0
As expected, two colors.
With file_per_shape option I also got only one material-file with content:
newmtl Lot_30
    Ka 0 0 0
     d 1
    Tf 1.0 1.0 1.0
    Ni 1.0
 illum 3
    Ks 0 0 0
    Ns 0
MatthiasBuehler1
with the 'per file' option, I correctly get:
newmtl CityEngineMaterial
illum 3
Ka 0 0 0
Ks 0 0 0
Ns 0
d 1
Tf 1.0 1.0 1.0
Ni 1.0
newmtl CityEngineMaterial_1
illum 3
Ka 0 0 0
Ks 0 0 0
Ns 0
d 1
Tf 1.0 1.0 1.0
Ni 1.0
Can you post a screenshot of all your export settings ?
Hmmm...
