"Hole" in cityengine
5929
32
03-24-2014 03:50 AM
AnaGalego
I have with troubles to enter private buildings thoroughfares.
the cityengine not assume that those playgrounds are empty. anyone have a solution?
MatthiasBuehler1
Hi !
I just got some feedback from a developer regarding holes and importing them
( Not 100% all of the above was stated correctly by me)
To clarify: holes are supported with following input formats:
??? CityEngine 2013.1: gdb
??? CityEngine 2014.0: gdb, shp
So if you import footprints with holes into CityEngine 2013.1 we recommend to use the gdb format.
MatthiasBuehler1
I'm sorry, but I don't understand what you mean ..
Please post screenshots .. Ok ?
matt
AnaGalego
In arcgis i have image1 but in city i have image2..
i need the hole in center..
LeonidKrylov
It's the only reason we do not use CE in my company. Unfortunately, we had to write Python and Max scripts to export from ArcGIS to 3dsmax. I tested each CE release from 2008 version but every time this problem remains unsolved.
MatthiasBuehler1
in CE 2013, this should work.
Ana, can you post a shape file or GDB with that specific footprint ?
Let me know ..
matt
AleksandarLalovic
I am experiencing the same problem.
Usually i import DXF files and closed polylines are converted to CE shapes. What usualy happens with the holes is that CE reads it as a second shape. What kind of objects should i export from AutoCAD to preserve the holes?
In VecrorWorks, the same thing hapens both when exporting to DXF or to ShapeFiles, the object with a hole is being impoted as two seperate shapes.
Any ideas?
[ATTACH=CONFIG]33161[/ATTACH]
MatthiasBuehler1
Until CE2012, CityEngine could not interpret holes, thus it created a second shape, with inverted normals.
In 2013, it is supported for shapeFiles and GDB. I'm not sure if it's also working with dxf files.
Alex, can you provide a dxf file with a polygon with a hole ?
LeonidKrylov
http://take.ms/5YWu4 ArcScene extrusion
http://take.ms/eWOnC CE 2013.1 extrusion
MatthiasBuehler1
thanks for the screenshots.. but I need test files too .. 🙂
LeonidKrylov
.rar in attach!
