version "2010.3" attr height = 10 attr blue = "#0066ff" attr angle = rand(35,45) Lot--> setback(10) { street.front : NIL | street.back: Backyard | remainder : Building } Building --> s(10,height,10) center(x) extrude(height) comp(f) { side : Facade | top(0): Roof } Backyard --> setback(2) { street.back: NIL | remainder : Garage } Garage --> s(5,5,5) center(x) extrude(5) comp(f) { side : Facade | top(0): Roof } Facade --> color(blue) Roof --> roofHip(angle) color(blue)
version "2010.3" ###################################################### # Imported Rules # #import Plant_Distributor:"rules/Plant_Distributor_with_LumenRT_Models.cga" ###################################################### # Control Attributes (user accessible) # ##Lot Attributes @Group("Lot Attributes") #Flip buildings to face rear of the lot. @Group("Lot Attributes") @Order(1) @Range("true","false") attr FlipFront = "false" #Front and rear setbacks (unit = meters) @Group("Lot Attributes") @Order(2) @Range(1, 20) attr FrontSetback = 5 @Group("Lot Attributes") @Order(3) @Range(1, 20) attr GarageSetback = 2 ##House Attributes: @Group("House Attributes") #House Height: @Group("House Attributes") @Order(1) @Range(5,25) attr HouseHeight = 5 #House size (percentage of lot) @Group("House Attributes") @Order(2) @Range(0.35,0.7) attr HouseLength = rand(0.50,0.55) @Group("House Attributes") @Order(3) @Range(0.5,0.95) attr HouseWidth = rand(0.7, 0.75) ##Garage Attributes: @Group("Garage Attributes") @Group("Garage Attributes") @Order(1) @Range(5,10) attr GarageHeight = 5 ## Landscaping: @Group("Landscaping") @Group("Landscaping") @Order(1) @Range(1,5) attr NumTrees = 1 @Group("Landscaping") @Order(2) @Range(10,20) attr treesize = rand(15, 20) ###################################################### # Constants (Landscaping only, hidden from user) # const grass = "grass/grass.jpg" const tree = ("Plants/White_Oak/White_Oak_Model_0.obj") //make dropdown for tree species selector? ###################################################### # Begin Rule with Lot # # Designate a setback from the front and rear of the property. # Assign the front setback area as the Yard, the back setback as the Backyard # Area not within the setbacks will be where the House is generated. @StartRule Lot--> case FlipFront == "false": #Replicated grass across Lot setupProjection(0, scope.xz, 5, 5) projectUV(0) texture(grass) Ground. setback(FrontSetback) { front: Yard | back: Backyard | remainder : House} else: #Flip the orientation to generate the buildings facing the rear mirrorScope(true, false, false) setupProjection(0, scope.xz, 5, 5) projectUV(0) texture(grass) Ground. setback(FrontSetback) { front: Backyard | back: Yard | remainder : House} # Import the Plant distributor (2013 Vegegtation rule) and # Place a tree of random size in the front yard Yard --> offset(-2,inside) scatter(surface, NumTrees, gaussian) { Veg } Veg --> alignScopeToAxes(y) s(0,treesize,0) i(tree) House --> case FlipFront == "false": s('HouseWidth,HouseHeight,'HouseLength) center(xz) extrude(world.y, HouseHeight) comp(f) { front: FrontFacade | side : SideFacade | top: Roof } else: rotateScope(180,0,180) s('HouseWidth,HouseHeight,'HouseLength) center(xz) extrude(world.y, HouseHeight) comp(f) { front: FrontFacade | side : SideFacade | top: Roof } Backyard --> case FlipFront == "false": setback(GarageSetback) { back: NIL | remainder : Garage } else: setback(GarageSetback) { front: NIL | remainder : Garage } #Construct the garage in the back of the Lot Garage --> case FlipFront == "false": s(7,GarageHeight,5) center(xz) extrude(world.y, GarageHeight) comp(f) { back : GFront | front : SideFacade | side: Facade | top: Roof } else: rotateScope(180,0,180) s(7,GarageHeight,5) center(xz) extrude(world.y, GarageHeight) comp(f) { back : GFront | side: Facade | top: Roof } ###################################################### # Building Facades # const minWallSizeAtCorner = 0.8 FrontFacade --> split(y) {4 : MainFloorFront | ~1 : Facade #UpperFloor? } HouseFront --> split(x) { minWallSizeAtCorner : Facade | ~1 : HouseFront | minWallSizeAtCorner : Facade } MainFloorFront --> split(x) { 3 : SideFacade | 1.2 : FrontDoorWall | 1 : Facade | ~1 : SideFacade } FrontDoorWall --> split(y) { 2.2 : FrontDoor | ~1: Facade } FrontDoor --> extrude(-0.15) setupProjection(0, scope.xy, scope.sx, scope.sy) projectUV(0) texture("textures/door.png") // End of Front ##################################################### # The Window mayhem # # ~A work in progress~ const Window_Width = 2.2 const SingleWindow = 1.2 const DoubleWindow = 3.4 SideFacade --> split(x) { minWallSizeAtCorner: Facade | ~1 : WindowArea | minWallSizeAtCorner: Facade} WindowArea --> split(y) { 1 : Facade | 1.75 : WallSplitter | ~1 : Facade } # ^above is working ##################################################### # Split walls into segments for window placement # WallSplitter--> case scope.sx > (DoubleWindow): split(x) {3.4 : WindowFrame2 | ~1: Facade }* case scope.sx > SingleWindow: split(x) { 1.2 : WindowFrame | ~1: Facade }* else: Facade WindowFrame --> split(x) { ~1 : Facade | 1.2 : WindowActual | ~1: Facade } WindowFrame2 --> split(x) { 0.5: Facade | 1.2 : WindowActual | 1.2 : WindowActual | 0.5 : Facade } DoubleWindowFrame --> split(x) { 0.5: Facade | 1.2 : WindowActual | 1.2 : WindowActual | 0.5 : Facade } # Drops in the window texture DoubleWindowActual --> #extrude(-0.15) setupProjection(0, scope.xy, scope.sx, scope.sy) projectUV(0) texture("textures/window.png") # Drops in the window texture WindowActual --> #extrude(-0.15) setupProjection(0, scope.xy, scope.sx, scope.sy) projectUV(0) texture("textures/window.png") ##################################################### # The Garage! # # GFront --> split(x) {0.67 : Facade | ~1 : GarageDoor | 0.67 : Facade} #split(y) {0 : Facade | ~1 : GarageDoor | 0.5 : Facade } GarageDoor --> split(y) { ~1 : GarageDoorTx | 1 : Facade } GarageDoorTx --> setupProjection(0, scope.xy, scope.sx, scope.sy) projectUV(0) texture("textures/DoubleGarage2.png") #texture("textures/garage.jpg") ##################################################### # The main wall Facade # # Other textures to be added for Randomization const FacadeRandTexture = "textures/wall_stones.png" Facade --> setupProjection(0, scope.xy, 10, 10) projectUV(0) texture(FacadeRandTexture) ###################################################### # Roof Texturing # Note: 50% chance of Hipped roof, else Gable roof. # # Other textures to be added for Randomization #Roof Angle (house and garage) const roofangle = rand(33,35) const RoofRandTexture = "textures/roof.jpg" Roof --> case p(0.5) : roofHip(roofangle, 0.75) comp(f) {all: RoofTexture} else: roofGable(30, 0.75) comp(f) {top: RoofTexture | side : Facade} RoofTexture --> alignScopeToGeometry(yUp, any, world.lowest) setupProjection(0, scope.xz, 6, 6) projectUV(0) texture(RoofRandTexture)
