3DS Max Export
2456
11-04-2011 01:33 PM
JonasSilva
Can i export lines from 3dsmax and import in City Engine and turn this lines a Block to generate my city?
What's the easiest  way to create buildings with my 3dsmax model? I have lines model or planes model. I just wanna put some buildings in this area.
Thanks!
MatthiasBuehler1
hi !
you should be able to port your lines with dxf, if Max can export lines ( curves ) to dxf. though, make sure they're straight segments, curves are not supported.
you could also import polygons as static shapes into the CE and create buildings based on those shapes.
Though I guess the easiest is to create everything in the CE, from lines to shapes to models. ok ?
