3d polyline shapefile import - Problem on Z scale
3340
02-28-2014 11:44 AM
AdamDuncan
Hi all. I'm modeling a Canadian town for a school project. Loving the rules based modeling for shaping buildings, but having some trouble with road imports.
I've got a polyline file in ArcScene. I interpolate the shape from tin no problem (Picture 1)... but the polylines continue acting up on the z scale when imported as a shp.
It seems that a polyline cannot change vertical direction through its course. This has caused, for example, a road that traverses the crest of a hill and terminates at another road, to wind up a cull de sac higher than that road where the intersection should be (See Picture 2). I thought I had a solution by opening the editor and merging all polylines, but this has caused the shapefile - already interpolated to shape -- to be completely flat in CityEngine (Picture 3).
Is this a problem with shapefile import? What other options could there be for 3d polylines from ArcScene? Thanks for your help!
Adam
[ATTACH=CONFIG]31880[/ATTACH][ATTACH=CONFIG]31881[/ATTACH][ATTACH=CONFIG]31882[/ATTACH]
by Anonymous User
Not applicable
Original User: matthiasbuehler
what do you mean by 'It seems that a polyline cannot change vertical direction through its course' ?
do you want to don't want the elevation ?
an other tip: Check the docs on the 'cleanup graph' settings in the import dialog. deactivating some of those settings may give you better results.
Matt
AdamDuncan
I meant the Y scale, sorry... different than ArcScene.
I'm just importing and extruding within the program now, it's much easier. Thanks for your help.
by Anonymous User
Not applicable
I'm now not sure.. Is the issue solved ?
If not, try maybe a GDB with a feature class that supports z values, that should work..
Lemme know..
m.
