(2019.0) comp(f) breaks pipe geometries
1231
6
07-25-2019 07:29 AM
LR
When I try to comp pipes, the geometry flies apart despite nothing telling it to do so. Is this expected behavior?
Here's the rule:
@Range(true,false)
attr Comp = true
@StartRule
 Lot -->
 	case Comp == true: comp(f){all: X.}
 	else: X.
CherylLau
Looks like a precision problem.  We are looking into it.  Thanks for reporting this.
DavidWasserman
L R‌ - Does the result change if you use?:
comp(f){all = X.}
Even if so, that is weird. Are shapes translating?
David Wasserman, AICP
DavidWasserman
Is it creating new shapes or moving the old ones? It almost looks like floating point precision error when it resets the the shapes...how small is this pipe?
LR
Only the successor shapes move. The original does not move. The pipes are 25cm across. Operator "=" doesn't have the error which is probably because no position calculation happens in that case.
CherylLau
This is unexpected behavior, and I suspect it might be due to precision (or maybe even non-planarity).  I can't reproduce it though.  Would you be able to post your scene file please?
LR
I would pm it, if I could.
CherylLau
