Traffic
1586
05-11-2023 06:13 AM
RonKrefman
Nearby traffic element no longer working. I have infographic template that is missing cross streets and traffic counts whereas it previously worked. I've created a bug: ID:  BUG-000158203 but no activity yet.
Anyone have an idea how to remedy?
CherylHagevik
@RonKrefman Thank you for reaching out with your question and for working with Support to report this issue. The behavior you are seeing is related to an issue with the Infographics builder where the traffic layer is currently not available to configure. The fix for this issue is scheduled to be available with the June 2023 release, coming up in about a month. We appreciate your patience on this issue and apologize for the inconvenience! Until the fix becomes available to you, please consider using the following option as a workaround:
When building the infographic and adding an element, select “Nearby” -> “Browse for a layer on ArcGIS” -> “Living Atlas” -> Search “Traffic Counts”. This layer includes many of the fields and associated data present in the missing option for the nearby traffic workflow.
CherylHagevik
RonKrefman
That worked, thank you!
