Infographic PDF Export
1664
07-29-2022 06:23 AM
JoshDryer2
When I create a site (3,5,10 mile radius for example) and run a custom infographic, it creates the infographic for the smallest radii (3 miles in this case) with an option to toggle each panel to see the data for the other radii.
When I export the custom infographic as a PDF, it only displays the 3 miles radii data in the report.
My question is: Is there a way to export the infographic as a PDF that displays the infographic reports for every radii (3, 5, & 10)?
FasilTiru
@JoshDryer2
It looks like you have a comparison table in your custom infographic template. That causes other panels to show a drop down selection as you explained.
My recommendation is to replace your comparison table with another table style using the option below so you can view the variables for each ring one at a time.
Then you can use the site drop down selection on the top to view the infographics for each ring.
You also have the option to compare the rings side by side.
And when you export it to PDF, it will contain 3 pages for all rings.
Or you can export it as a side by side comparison PDF.
I hope this helps.
Fasil T.
Business Analyst Team
FasilTiru
@JoshDryer2
I hope this helps.
Fasil T.
JoshDryer2
Thank you, my friend. This is a great solution for me!
Josh
