ArcGIS Business Analyst Blog
101
59.8K
56
Open | It would be really helpful to add state legislative districts (upper and lower) as standard geographies in Business A... by ArielLow2146 Occasional Contributor II 0 1 | 0 | 1 | |
Open | It would be best to have an option to increase the maximum limit over the current value of 5,000 points when using Ar... by kntr New Contributor III 1 1 | 1 | 1 | |
Open | Currently if you've added a chart or an infographic there is no way to add other elements to the chart or infographic... by ArielLow2146 Occasional Contributor II 1 0 | 1 | 0 | |
Open | There used to be a 'number of households that own a pet' data point, but now there is just owns 1 dog, owns 1 cat etc... by KevinO_Brien New Contributor II 0 1 | 0 | 1 | |
Under Consideration | I am building a custom infographic and have set up a number of charts to use compare with geographies. I would like t... by ArielLow2146 Occasional Contributor II 1 2 | 1 | 2 | |
Open | I work in a small group that uses Community Analyst to create territories maps. I wish you could change the default ... by CarsonSuppe New Contributor II 1 1 | 1 | 1 | |
Implemented | We are using the infographics tool in Business Analyst to make custom infographics for each county in our state. (Cur... by AmyRoust Occasional Contributor III 1 4 | 1 | 4 | |
Open | I submit two ideas for enhancing the Color Coded Layer tool.1. Maximum sample sizeIs it possible to set the "Maximum ... by SanaeIshibashi1 New Contributor II 1 0 | 1 | 0 | |
Implemented | Although I can do this through some manual steps or a model, I would love to have an option for the Generate Grids an... by SusanZwillinger Occasional Contributor 2 6 | 2 | 6 | |
Open | Several students in a class I teach about using Business Analyst Online have suggested a clearly outlined or labelled... by Dr_Mighty New Contributor II 2 0 | 2 | 0 | |
In Product Plan | Using online BA data in ArcGIS Pro is very helpful when doing demographic type research. It is often useful to look a... by LancePompe New Contributor II 1 1 | 1 | 1 | |
Open | The new comparison panel is awesome - thank you! I think conditional text (value)/images (arrow?) would be a great ad... by ColinMcNamara New Contributor III 1 2 | 1 | 2 | |
Open | Some of the reports that rely on InfoUSA's data can be fairly inaccurate, but the ability to modify the inputs for th... by JonathanBarnett1 New Contributor II 1 0 | 1 | 0 | |
Under Consideration | When conducting a Business search within Business Analyst online, it would be really useful to have the actual indust... by Brian_Colson New Contributor III 2 2 | 2 | 2 | |
Closed | Hi there, it would be very useful to access BAO using arcgis api for Python.Would you happen to know if something lik... by Roxana_ElenaUrdea New Contributor III 0 2 | 0 | 2 |
Idea Submission Guidelines
