Our organization has collected bathymetry data through the use of an AUV (.logdoc) and lowrance side scan sonar (.Sl2). Is there a way to use these data file formats in ArcMap bathymetry? In order to add bathymetry, I know it needs to be in gridded raster format (BAG, GeoTIFF) or a point feature class (w/ footprint polygon).
I was able to convert the SL2 files into kml and/or csv using an online converter.
Not sure how to move forward. Any recommendations would be appreciated.
Hello @GBForever ,
If you have your data in a CSV format, you can convert it to a point feature class using the ASCII 3D To Feature Class geoprocessing tool.
Another option could be to use add x,y coordinate data as a layer and save the layer as a feature class.
Paulina
Hi Paula,
I had trouble using the geoprocessing tool and I'm not sure why. perhaps it has something to do with my data.
In using point data, a footprint polygon is needed. Do I need the Defense Mapping extension to create this or can it be done with another tool and still be used in bathymetry?
What about the add x,y coordinate data as a layer workflow? Was it successful?
For the footprint, try to use the Minimum Bounding Geometry geoprocessing tool with the CONVEX_HULL option.
