Hi. In a popup, I'm struggling to remove extra white space between elements. So, I have a text element, then an arcade element followed by a text element. There is extra space between each of these. In the snip below, you can see that there is a lot of space btwn the arcade element, which is a table of zoning info and the text elements above and below it.
Is there some way to remove that so that the 'Planning' portion is more compact?
Here is how the popup is configured
