Windows App installation without un-install any previous version.
1622
01-27-2021 01:25 PM
SeanKim
Recently, I've seen one of the changelogs for the App Studio 4.4 which can be install a new Windows app without un-install as like below link shown.
What's new in AppStudio—ArcGIS AppStudio | Documentation
Anyway, my build couldn't do that, and I can confirm that I am currently using 4.4.77 to cloud make.
Is there any option to set it?
Sean.
ErwinSoekianto
Esri Alum
@SeanKim
Did you enable the appinfo.json property "desktop.allowOverwrite"? https://doc.arcgis.com/en/appstudio/extend-apps/editappinfo.htm
"desktop.allowOverwrite" —This property is added under deployment. If set to true, the app can be installed on Windows without uninstalling a previous version of the app.
We did not enable this feature by default since it is only working on Windows.
Thank you,
Erwin.
ErwinSoekianto
Esri Alum
@SeanKim
Thank you,
Erwin.
SeanKim
Thanks Erwin,
I have added an allowOverwrite under deployment and works perfect!
Thanks for your help.
Sean.
