White screen issue on IPad
1316
10-09-2020 05:39 AM
BrentSlone3
Hi team this white screen issue is related to the previous thread: ArcGIS AppStudio Cloud Make Build for IOS and Android gives white screen
We are using QuickReport template
On commenting the onComposeError or changing onCompseError to onErrorChanged tha apps are working fine on Android and IPhone however the issue still persists on IPad
Following is the configuration of our testing device:
We are using the latest version of AppStudio, we are building the apps using CloudMake
Any suggestions would be helpful.
Thank you
ErwinSoekianto
Esri Alum
Brent,
The white screen issue normally related to QML issue. Can you try running your app in AppRun in AppStudio Desktop?
Also if you can send the application or share it publicly then share the name to us, we can probably try to help troubleshoot. Or let's work it with Esri Technical Support‌, so that we can troubleshoot and see what the issue is.
Thank you,
Erwin.
