Is there any QML API support for calling a geoprocessing service?
7585
17
11-11-2015 11:03 PM
by Anonymous User
Not applicable
I can't find anything in the docs so thought it worth asking...
Cheers
-Paul
GarethWalters
Hi Paul,
If there is nothing in Runtime that hooks in, then you could always get to it via the REST interface using the NetworkRequest component.
GarethWalters
Hi Paul,
LucasDanzinger
Esri Frequent Contributor
Our Runtime QML API does not support GP yet. However, we plan to support it in our Quartz release, so until AppStudio is able to move to this, you will need to do what Gareth suggests and perform your own REST request.
RuthannL1
Is there an example that demonstrates a REST request for a geoprocessing service on a server?
Ruthann
RaphaelWitt
I am highly interested in this topic. So I ask again: Is there an example of a REST request for a GP service on a server?
That would help me a lot!
Greetings and thanks,
Raphael
GarethWalters3
Hi Raphael,
there is a sample in AppStudio called networkrequest. It will show an example of making rest calls to an arcgis server. You should be able to follow that and modify it to call a GP service.
cheers,
gareth
RaphaelWitt
Hi Gareth,
thanks for your reply! I tried figuring out how I can call my GP service. I have read the entire docu but I have the following problem:
I want to call my GP service in the networkrequest sample, but how can I specify the input in QML? I tried to build the URL like the examples at ArcGIS REST API :
"http://sampleserver2.arcgisonline.com/ArcGIS/rest/services/PublicSafety/EMModels/GPServer/ERGByChemi...{ \"features\" : [{ \"geometry\" : {\"x\" : -104.44, \"y\" : 34.83}, \"attributes\" : {\"Id\" : 43, \"Name\" : \"Incident\"}}]} &Material_Type=&Wind_Bearing__direction_blowing_to__0_-_360_=&Day_or_Night_incident=&Large_or_Small_spill=&env:outSR=&env:processSR=&f=html"
I thought I need the "..." specified in my URL, but I get the following error message:
"NetworkRequest::setErrorText(const class QString &) "Protocol \"\" is unknown"
Is there another way to call my GP service with specified input?
Thank you in advance!!
Raphael
jaykapalczynski
Honored Contributor
Did you ever figure this out....
I have a GP Service running and I can input values and it works great...
I just cant figure out how to call that Service from AppStudio and pass it the input parameters.
LucasDanzinger
Geoprocessing is now available in ArcGIS Runtime. You should be able to create a GeoprocessingTask by pointing to your service URL, create/modify parameters, and execute the task/job.
Here is the API ref doc - GeoprocessingTask QML Type | ArcGIS for Developers
Here is some conceptual doc for GP in Runtime - Run a geoprocessing task—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
Here is a sample of using the GeoprocessingTask - arcgis-runtime-samples-qt/ArcGISRuntimeSDKQt_QMLSamples/Analysis/AnalyzeViewshed at master · Esri/ar...
jaykapalczynski
Honored Contributor
THANK YOU FOR YOUR RESPONSE
I have been trying to use that sample for a bit now....new to this....I am simply trying to pass a few parameters to a GP service.  Not sure if I have to create a FeatureCollectionTable?
This does not work...but i know the GP service works because I can manually run it....I just cannot figure out how to pass the values
Does anything stick out to you below.
Im stuck on #3
If I console.log viewshedParameters below there is nothing in the objects:{} in the object
 // ON BUTTON CLICK
  viewshedTask.calculateViewshed();
GeoprocessingTask {
    url: "https://xxxx/arcgis/rest/services/x/x/GPServer/NewScriptToRun"
    function calculateViewshed() {
         var paramsvalue = {'OBJECTID':ObjectID,'comments':Comments};
         var viewshedParameters = ArcGISRuntimeEnvironment.createObject("GeoprocessingParameters",
  {executionType:Enums.GeoprocessingExecutionTypeSynchronousExecute,objectName:"Parameter Name",inputs:paramsvalue });
         viewshedJob = viewshedTask.createJob(viewshedParameters);
         viewshedJob.start();
import arcpy
from arcpy import env
import os
# Geting user input for project name, status, type, submital date and planner name
varObjectID = arcpy.GetParameterAsText(0)
varItem = arcpy.GetParameterAsText(1)  ‍‍‍‍‍‍‍‍‍‍‍‍‍‍
