Error upliading ipa to app store
1630
04-07-2020 04:27 AM
JorgeFrade_Martínez
ErwinSoekianto
Esri Alum
Jorge,
With AppStudio 4.2, iPad Multitasking is enabled by default. With that being said, if iPad Multitasking is enabled, all four orientations need to be supported in the app.
Based on the screenshot you provided, it looks like your app has landscape options disabled. Please enable all four orientations if you want to enable iPad Multitasking.
But if you don't want or intend to have iPad Multitasking enabled, you can set display.ios.windowsMode to "fullscreen" in appinfo.json
"display": {
   "ios": {
        "windowMode": "fullscreen"
Thank you,
Erwin
ErwinSoekianto
Esri Alum
Jorge,
"display": {
   "ios": {
Thank you,
Erwin
JorgeFrade_Martínez
I want to use only the portrait mode. I added the fullScreen key to the appinfo.json but i still have the same problem...
ErwinSoekianto
Esri Alum
 My apologies, the correct appinfo.json value to disable iPad Multitasking is below (they case sensitive), I will update the original post.
"display": {
   "ios": {
