change basemap through token and item id
1317
07-27-2020 03:15 AM
rsharma
I have been trying to access my private topological basemap in my app through btn click  and calling chooseBasemap(); fnc.
But it does not load my basemap. screen goes blank
this is my code below:
import QtQuick 2.13
import QtQuick.Controls 2.13
import QtQuick.Layouts 1.13
import QtPositioning 5.8
import QtLocation 5.9
import ArcGIS.AppFramework 1.0
import Esri.ArcGISRuntime 100.6
import "../assets/js/backend.js" as Backend
import "../controls" as Controls
Page {
    property string itemID: "my map id"
    property string tItemId:"topo map id"
     property real scaleFactor: AppFramework.displayScaleFactor
    width: parent.width
    height: parent.height
    MapView {
        property real initialMapRotation: 0
        anchors {
            left: parent.left
            right: parent.right
            top: parent.top
            bottom: parent.bottom
        rotationByPinchingEnabled: true
        zoomByPinchingEnabled: true
    // add a basemap
    Map {
        item: PortalItem {
            portal: portal
            itemId: itemID
    }//End Mapview
    //! [PortalUserInfo create portal]
    Portal {
        credential: Credential {
             token: Backend.getMapToken()
        Component.onCompleted: {
            load();
            //fetchLicenseInfo();
        onLoadStatusChanged: {
            if (loadStatus === Enums.LoadStatusFailedToLoad)
                retryLoad();
    Row{
        anchors.horizontalCenter: parent.horizontalCenter
        //anchors.margins: 70 * scaleFactor
        spacing:3
        leftPadding: 120
        topPadding: 15
        Controls.Kbutton {
            width: 100
            text: qsTr("SATELLITE")
            font.weight: Font.Bold
            Layout.alignment: Qt.AlignHCenter
            Layout.preferredWidth: 100
            borderColor: "#ff7919"
            font.pixelSize: 14
            Layout.preferredHeight: 40
            baseColor: "#FF7919"
            textColor: "#FFFFFF"
            onClicked: {
                    map.basemap = ArcGISRuntimeEnvironment.createObject("BasemapImagery");
        Controls.Kbutton {
            width: 88
            text: qsTr("TOPO")
            borderColor: "#ffffff"
            font.pixelSize: 14
            baseColor: "#ffffff"
            textColor: "#333333"
            onClicked: {
                chooseBasemap();
        Image {
            source: "../assets/images/Group1.png"
            height: 60
            width: 60
    Row{
   topPadding: 70
   leftPadding: 315
    Image {
        source: "../assets/images/Group22.png"
        height: 60
        width: 60
    function chooseBasemap() {
        var newMap = ArcGISRuntimeEnvironment.createObject("Map", {basemap: tItemId});
        mapView.map = newMap;
        mapView.visible = true;
    footer: Controls.Kfooter {
rsharma
Finally i get the result But does this code replace my drawing polygons and
,markers also which i m going to put in future in this code??
I just want to change basemap with my secured map here..
Can anyone tell me that i am going right way
               var credential = ArcGISRuntimeEnvironment.createObject("Credential", {  token: Backend.getMapToken() });
                var  securityPortal = ArcGISRuntimeEnvironment.createObject("Portal", { credential: credential });
               var item = ArcGISRuntimeEnvironment.createObject("PortalItem", { portal: securityPortal, itemId: tItemId });
               mapView.map= ArcGISRuntimeEnvironment.createObject("Map", { item: item });
rsharma
i am also trying this way: but nothing shows on screen
        console.log(ArcGISRuntimeEnvironment.createObject("Map", {portal: portal,itemId: itemID}));
        mapView.map = ArcGISRuntimeEnvironment.createObject("Map", {portal: portal,itemId: itemID});
rsharma
ErwinSoekianto
Esri Alum
I think that is correct, you could probably re-use the Portal and Credential object that you already have.
Tagging ArcGIS Runtime SDK for Qt‌ to see if there is a better way to solve this.
