Appstudio quickreport make iOS app error 498
1042
08-21-2020 02:54 PM
JaguarDigital
Hi
I'm working on a Mac Catalina OS. When I try to compile an Appstudio Quickreport iOS app it throws an error code 498: invalid token.
Previously I received three errors in the build process,
- the first because of an error in the Provisioning Profile,
- the second because the Certificate had an error,
- and the last one because the I was using the wrong password.
Currently, the Provisioning Profile, Certificate (.p12) and Apple Password are already set (below images), but at the end of the Build process, after 1.5 hours aprox. of building process (and 30 minutes at 99%) it threw the error on the image above
What can be wrong?
Any help will be appreciated, thanks
Oscar
JaguarDigital
I built the app again and it worked fine, I have access to the .ipa now on the cloud make.
I suppose it was due to the long build time, that the token expired, maybe? The good thing is that it's working now
JaguarDigital
