How to show Images In a row using repeater in qml?
4107
08-22-2020 01:21 AM
x_d
so i have to show 9 images on my page, so I have used repeater, but the problem is that I want to show the images in a row, but in out put it shows in a column. I am working on a mobile application using qml. So can anybody suggest me how to show it in a row format using qml?
Here is my code
ColumnLayout {
        spacing: 10
        clip:true
        Repeater{
        model: 9
                Row{
                   spacing:30
                   Layout.alignment: Qt.AlignHCenter
                      Image {
                        source:"path to images"
                        height: 50
                        width:50
by Anonymous User
Not applicable
Read up on GridLayout which allows you to specify the maximum number of columns
GridLayout QML Type | Qt Quick 5.15.0
by Anonymous User
Not applicable
Do a google search for "qml layout" and you will see there are several layout types.
You are using ColumnLayout which is why they are displayed in a column. Try RowLayout or GridLayout for different options.
x_d
Yeah it was a silly mistake. but can you suggest me how can i put a condition  that in one row it only can consist of 4 images if it will more than 4 then after 4th image it will be in 2nd line. well i am showing images dynamically it's not hard coded
by Anonymous User
Not applicable
x_d
thanks it worked
