AppLayout / StatusBar doesn't work with Page footer
893
05-17-2022 01:16 PM
by Anonymous User
Not applicable
Using the StatusBar app template, if I add a footer of type TabBar to the App, it is pushed down below the screens painted area. If I exaggerate the height to 100 or more then the footer moves up into the view more. I'm just worried this may create an abnormally large footer on some devices.
/* Copyright 2021 Esri
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *    http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
import QtQuick 2.9
import QtQuick.Layouts 1.1
import QtQuick.Controls 2.2
import QtQuick.Controls.Material 2.2
import QtGraphicalEffects 1.0
import QtQuick.Dialogs 1.2
import QtQuick.Layouts 1.3
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Platform 1.0
import "controls" as Controls
AppLayout {
    width: 400
    height: 750
    delegate: App {
        height: appLayout.height
        width: appLayout.width
        function units(value) {
            return AppFramework.displayScaleFactor * value
        property real scaleFactor: AppFramework.displayScaleFactor
        property int baseFontSize : app.info.propertyValue("baseFontSize", 15 * scaleFactor) + (isSmallScreen ? 0 : 3)
        property bool isSmallScreen: (width || height) < units(400)
        StackView {
            initialItem: landingPage
            anchors.fill: parent
        Component {
            Page {
                header: ToolBar {
                    width: parent.width
                    height: 50 * app.scaleFactor
                    Material.background: Material.color(Material.Purple)
                    Material.elevation: 0
                    Controls.HeaderBar{}
            footer: TabBar {
                contentHeight: 60 * app.scaleFactor
                position: TabBar.Footer
                background: Rectangle {
                    color: "blue"
                TabButton {
                    height: 60 * app.scaleFactor
                    Text {text: "hey"}
                TabButton {
                    Text {text: "hey"}
                Rectangle {
                    anchors.margins: 5 * app.scaleFactor
                    color:"#F5F5F5"
                    // sample starts here ------------------------------------------------------------------
                    ColumnLayout {
                        spacing: 20 * app.scaleFactor
                        Item {
                            Layout.preferredHeight: 20 * app.scaleFactor
                        ComboBox {
                            Layout.alignment: Qt.AlignHCenter
                            displayText: "Color: " + currentText
                            currentIndex: Material.Purple
                            Layout.preferredWidth: parent.width * 0.7
                            model: ListModel {
                                ListElement { name: "Red" }
                                ListElement { name: "Pink" }
                                ListElement { name: "Purple" }
                                ListElement { name: "DeepPurple" }
                                ListElement { name: "Indigo" }
                                ListElement { name: "Blue" }
                                ListElement { name: "LightBlue" }
                                ListElement { name: "Cyan" }
                                ListElement { name: "Teal" }
                                ListElement { name: "Green" }
                                ListElement { name: "LightGreen" }
                                ListElement { name: "Lime" }
                                ListElement { name: "Yellow" }
                                ListElement { name: "Amber" }
                                ListElement { name: "Orange" }
                                ListElement { name: "DeepOrange" }
                                ListElement { name: "Brown" }
                                ListElement { name: "Grey" }
                                ListElement { name: "BlueGrey" }
                            delegate: ItemDelegate {
                                text: modelData
                                width: colorBox.popup.width
                                Rectangle {
                                    parent: colorDelegate.background
                                    color: Material.color(index)
                            onCurrentIndexChanged: {
                                StatusBar.color = Material.color(colorBox.currentIndex)
                        ComboBox {
                            displayText: "Theme: " + currentText
                            currentIndex: Material.Dark
                            model: ListModel {
                                ListElement { name: "Light" }
                                ListElement { name: "Dark" }
                                text: modelData
                                width: themeBox.popup.width
                                StatusBar.theme = themeBox.currentIndex
                        Button {
                            text: "reset"
                            onClicked: {
                                StatusBar.theme = Material.Dark
                                themeBox.currentIndex = Material.Dark
                                StatusBar.color = Material.color(Material.Purple)
                                colorBox.currentIndex = Material.Purple
                        Item {
                            Layout.preferredHeight: 10 * app.scaleFactor
                        Label {
                            text: "Note: Status bars are not displayed by default on devices; it first has to be enabled by setting the property display.statusBar to true in the app's appinfo.json."
                            wrapMode: Label.Wrap
                        Item {
                            Layout.fillHeight: true
                            Layout.fillWidth: true
                contentItem: Rectangle {
                    anchors.top:header.bottom
        // sample ends here --------------------------------------------------------
        Component {
            Controls.DescriptionPage {
    Component.onCompleted: {
TrevorFrame
Hi @Anonymous User,
This is a well thought out and valid concern. Luckily, there are a few things that can be done to implement a responsive design to take care of this.
Firstly, and probably the simplest, is to remove the TabBar from the "footer" and set it as the last item of the ColumnLayout so it sits within the "body" of the page. Because the Item above it will fill height, it would force the TabBar to stay at the bottom of the page.
Some other responsive practices that can be implemented are to determine OS of device and set bool values for if the device has a small screen or not, then adjust component properties based on these values. See example below:
property bool isIphoneX: false //value set later
readonly property bool isMobile: ( Qt.platform.os === "ios") || (Qt.platform.os === "android")
property int notchHeight: isIphoneX ? 20 : 0
header: ToolBar {
   height: isMobile ? (50 * app.scaleFactor + app.notchHeight) : (!isSmallScreen ? 20 * app.scaleFactor : 35 * app.scaleFactor)
Best,
Trevor
