How did you assign an attribute to the flareclusterer graphic's maptip?
Inherit flarecluster and add your code in the OnCreateGraphic, but be sure to call the Overridden function of the base flareclusterer class so it still works. Something like this in VB
Protected Overrides Function OnCreateGraphic(ByVal cluster As GraphicCollection, ByVal point As MapPoint, ByVal maxClusterCount As Integer) As Graphic
Dim graphic As Graphic= MyBase.OnCreateGraphic(cluster, point, maxClusterCount)
If (cluster.Count <> 1) Then
If (cluster.Count <= Me.MaximumFlareCount) Then
'We only want to add this attribute to the "small" clusters, the ones that flare out when you mouseover
For Each g As Graphic In cluster
g.Attributes("CustomAttribute") = attributeValue
End If
Return graphic
Else
'these would be unclustered graphics, but my breakpoint here has never been hit...
End If
Return graphic
End Function
good luck!!Josh
