FlareClusterer - setting minimum distance
759
07-26-2012 09:51 AM
GaryBushek
Is there a way to tell the flare clusterer not to cluster when features are within a certain distance of each other? When zoomed in as much as possible the client wants to see the actual features when they're within 10-20 feet of each other and not the clustered graphic.  Im thinking not but I figured i'd check. You'd almost have to turn clusting off for a certain distance range and turn it back on if the points are located at the same location.
thanks
JoshPorter
Ive had good luck listening to the map's ExtentChanging event and checking the resolution. For my case, if the resolution of the map was less than 2 i would set the clusterer of the layer to null. This unclusterers the layer and shows each and every individual graphic.And when the maps resolution rose above my limit of 2, i would reassign the clusterer to the layer.
Josh
