When I try to use this Export Web Map Task in ArcGIS Server from a Silver-light Application the Server throws this error when a Feature Service is included...
Error executing tool.: Layer "Site Locations": Missing 'symbol' in simple renderer. Failed to execute (Export Web Map). Failed to execute (Export Web Map Task).
The service contains a very simple symbol. Am I missing something?
Some symbols (such as TextSymbol) are not supported by the print service. What is the type of your feature layer symbol?
Its just a very basic diamond found under the ESRI Default Marker - Character Marker Symbol
Also, the legend symbols don't render properly either for some reason.
Map symbol
Legend Symbol
Could you share a code snippet allowing to reproduce the legend issue?
In Silverlight, I'm doing this to submit the print job
var mapOptions = new MapOptions(mainMap); // mainMap is the ESRI Map object with some dynamic services and a feature service.
mapOptions.OutSpatialReference = new SpatialReference(26911);
var printParameters = new PrintParameters(mainMap)
MapOptions = mapOptions,
LayoutTemplate = "Tabloid",
Format = "PDF"
printParameters.ExportOptions = new ExportOptions() {Dpi = 300};
printTask.SubmitJobAsync(printParameters);
This is going to the built in Export to Web Map service in ArcGIS 10.3.
Hi Tony, did you got the resolution for this issue I am having similar problem. 80% of my symbols in the map document comes and remaining gives Junk character on export.
