ZOOM TO QUERY RESULTS
2575
03-28-2011 01:28 AM
vipulsoni
I need help for a query task which zooms to the results from the datagrid selection changed event.
In the given sample
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#QueryWithoutMap
If I click on the grid results the map should zoom/highlight to correct features.
Like in the find task sample > http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Find.
After  (through query task)  several attempts (all failed) I was not able to get the attributes filled in a datagrid , though I get a datagrid filled with rows (row count seems to be correct) but with empty records..white spaces
Please help as I dont know what I am doing wrong in my code.
DominiqueBroux
Esri Frequent Contributor
How is set the ItemsSource property of your datagrid?
Hw are set the columns?
vipulsoni
Thank you for the reply!
<slData:DataGridTextColumn Binding="{Binding Attributes[test]}" Header="test" />
                    <slData:DataGridTextColumn Binding="{Binding Attributes[name]}" Header="Name"/>
                    <slData:DataGridTextColumn Binding="{Binding Attributes[bld_id]}" Header="Bld_ID" />
                    <slData:DataGridTextColumn Binding="{Binding Attributes[Remark]}" Header="Remark"/>
I tried the above code for binding with the exact names as the attribute column names...but did not help..
in CS file -
FindDetailsDataGrid.ItemsSource = args.FeatureSet;
so i guess the binding of the datagrid was correct but what I wanted to know is that how in findtask sample on the datagrid selection changed event the map zooms to results ..same functionality I wanted to show with query task , so that I have my datagrid populated with some more fields other than the primary field thus helping the user to decide which feature he wants to select.
DominiqueBroux
Did you look at this sample : http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#SpatialQuery ?
The result of the query task is displayed in a datagrid, and when a row is selected, the feature is selected in the map.
Is it what you want to do?
vipulsoni
Thank you very much Dominique!
