TOC Questions
1286
09-13-2010 12:28 AM
UlfGrimhardt
Hi
I created following TOC from the Silverlight Samples Page:
<ListBox ItemsSource="{Binding ElementName=map, Path=Layers.[0].Layers}" MinWidth="330" Margin="5" FontWeight="Normal">
                                    <ListBox.ItemsPanel>
                                        <ItemsPanelTemplate VirtualizingStackPanel.VirtualizationMode="Standard" />
                                    </ListBox.ItemsPanel>
                                    <ListBox.ItemTemplate>
                                        <DataTemplate>
                                            <StackPanel Orientation="Horizontal">
                                                <CheckBox Margin="2"
                                                Name="WasserhaltungMXD"
                                                Content="{Binding Name}" Tag="{Binding ID}"
                                                ClickMode="Press"
                                                Click="CheckBox_Click2"
                                                IsChecked="{Binding DefaultVisibility}" />
                                            </StackPanel>
                                        </DataTemplate>
                            </ListBox.ItemTemplate>
Now i have two Question:
1. Is it possible to group the TOC by individual Groups, so that the List box consists of some kind of TreeView, and not all Sublayer-Checkboxes are shown at once??
2. Is it possible to create a Slider to change the Opacity of the Sublayers, like one can do it with the Layers??
DominiqueBroux
Esri Frequent Contributor
It is possible but it needs some developments to create the hierarchical data.
From version 2.1, a legend/TOC control will be provided.
No that's not possible. The opacity of sublayers is defined when publishing the service and can't be changed by the REST API.
YgorThomaz
EXCELENT NEWS!!!!!
DavidAshton
I have not downloaded 2.1 but I did read through the "What's New" and I did not see any mention of a legend/TOC control being provided.
Did this happen "From version 2.1, a legend/TOC control will be provided."
dotMorten_esri
Esri Notable Contributor
It's not available in the beta, but should be in the RC.
