Sublayer DynamicMapService
1471
5
07-05-2010 04:17 AM
SamuelDantas
I trying to let the user of my application to change the sublayer colors in a DynamicMapServiceLayer. Is it possible to achieve? Is there another approach to get the same effect (another kind of layer than DynamicMapServiceLayer maybe)?
dotMorten_esri
Esri Notable Contributor
The REST service does not allow for this, thus the client API's can't do it either.
SamuelDantas
Is there another way to achieve this, just like ArcMap does?
SamuelDantas
Any idea?
I need to know if this is at least possible.
LanceCrumbliss
DynamicMapServiceLayers are rendered on the server using the symbols defined per layer in the published map.  there is nothing the client-side application can do to change that (unless you want to use a FeatureLayer, but even that is not the same thing).  outside of a finer-grained arcobjects server-side approach (which wouldn't be very efficient in my opinion, and certainly not very easy) i don't think it's possible.
dotMorten_esri
As I mentioned in my previous answer this is not supported.
