Strange Crash
1542
11-10-2010 03:58 AM
MatthewPilgrim
I'm using the Silverlight MapPrinting example (with a couple of mods).  When panning and zooming in on an area I get a mysterious crash which I can't debug.  Running the process (without debuging) gives this error message:
Microsoft JScript runtime error: Unhandled Error in Silverlight Application Value was either too large or too small for an Int32.   at System.Convert.ToInt32(Double value)
   at System.Windows.PresentationFrameworkCollection`1.get_CountImpl()
   at System.Windows.PresentationFrameworkCollection`1.GetItemDependencyObject(Int32 index)
   at System.Windows.Controls.UIElementCollection.GetItemImplSkipMethodPack(Int32 index)
   at System.Windows.PresentationFrameworkCollection`1.CollectionEnum`1.get_Current()
   at ESRI.ArcGIS.Client.TiledLayer.getProgress()
   at ESRI.ArcGIS.Client.TiledLayer.bmi_DownloadProgress(Object sender, DownloadProgressEventArgs e, ImageTileInfo data, EventHandler`1 onProgressEventHandler)
   at ESRI.ArcGIS.Client.TiledLayer.<>c__DisplayClass8.<addTile>b__5(Object sender, DownloadProgressEventArgs e)
   at MS.Internal.CoreInvokeHandler.InvokeEventHandler(Int32 typeIndex, Delegate handlerDelegate, Object sender, Object args)
   at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName)
I understand that a number was "too large or too small for an Int32" and that this may have come from "ESRI.ArcGIS.Client.TiledLayer.getProgress()".  Does anyone have any suggestions as to how I should avoid or catch this?
Thanks, Matt
DominiqueBroux
Esri Frequent Contributor
Could you give more infos on how to reproduce this crash?
Does it look ramdom or does it happen each time after a specific sequence of actions?
MatthewPilgrim
Hi Dominique,
It occurs when heavily zooming in and out and panning.  A variation on the error just occurred:
Code: 4004
Category: ManagedRuntimeError
Message: System.OverflowException: Value was either too large or too small for an Int32.
   at System.Windows.PresentationFrameworkCollection`1.CollectionEnum`1.MoveNext()
   at ESRI.ArcGIS.Client.LayerCanvas.ArrangeOverride(Size finalSize)
   at System.Windows.FrameworkElement.ArrangeOverride(IntPtr nativeTarget, Single inWidth, Single inHeight, Single& outWidth, Single& outHeight)
If you mail me at "mattpil29 at google mail dot com" I'll send my slightly altered code.
Thanks, Matt
