Map doesn't exist in the namespace
1513
11-09-2010 02:41 PM
BenSher1
I'm testing a wpf/engine application and referencing the map namespace, but i get the error the name"Map" does not exist in the namespace "http://shcemas.esri.com/arcgis/client/2009
AliMirzabeigi
Could you please provide which version of the .Net Framework and the ESRI API you are using in your WPF application?
BenSher1
3.5 .net and 2.1 for silverlight api
AliMirzabeigi
This issue usually happens when you use the DLLs built for .Net Framework 4.0 in a .Net Framework 3.5 WPF application. Make sure you are using ESRI.ArcGIS.Client.dll file that is built for .Net Framework 3.5.
BenSher1
Thanks, that was it, just changed to point my project to .net 4 and we're good.
