Side-by-side install
1589
02-09-2010 05:34 AM
NeilDuxbury
Can you install the 2.0 API without uninstalling the 1.1 API?
Neil
dotMorten_esri
Esri Notable Contributor
Yes, but the templates will be overridden, and the default references in VS and Blend will point to the last installed API (to select v1.1 assemblies you have to explicitly browse to them and select them when adding a reference).
TedCronin
You can, they will both show up in the Add/Remove, but you will only see 1 template.  Also, this will cause problem when trying to remove, so I would not recommend it, since I am currently having issues with removal.
NeilDuxbury
Thanks for your responses.
Morten - Could this information be added to the Installation page in the online SDK.
Neil
RexHansen
Yes, we'll add information on side-by-side installs to the installation page in the SDK.
-Rex
