Selection in FeatureDataGrid
1336
03-28-2014 04:08 AM
UlfGrimhardt
Hello,
i have a question concerning the selection of a FeatureDataGrids or FeatureLayers.
In my Application i have a FeatureLayer and a FeatureDataGrid. If i select a row in the datagrid the feature in the map is selected and vise versa. Now i would like to select a Feature via CodeBehind. Is that possible?
For example i would like to select the feature by specific Attributes.
Thanks in Advance!
AhmedEl-Sisi
Hello,
Thanks in Advance!
you can select a feature via code behind using Graphic.Select() method or Graphic.Selected property.
for example, you can select some existing features from a FeatureLayer using somthing like the following:
List<Graphic> filteredGraphics = featureLayer.Graphics.Where(g => Convert.ToString(g.Attributes["AttributeKey"]) == "AttributeValue").ToList();
 foreach (Graphic g in filteredGraphics)
    g.Select();
UlfGrimhardt
Ok thank you for the help.
That works great if i set the FeatureLayer Mode to "OnDemand" or "Snapshot", but if i set it so SelectionOnly no Feature is shown.
The filteredGraphics List in your Code doesnt contains any Features so no Feautre is found.
It would be great if i could select a feature by code from the layer and just the features that fulfill the where-clause are shown in the DataGrid.
Do you have any Ideas concerning that problem?
Thanks in Advance
Ulf
AhmedEl-Sisi
Thanks in Advance
Ulf
Use FeatureLayer.WhereClause to filter your features and remove SelectionOnly Mode.
UlfGrimhardt
Thanks for the Info! That helped to solve my Problem!
