Problem with Geometry Service
913
04-14-2014 01:13 AM
DIALLOAbdoulaye
Hello Every One i have a problem with a geometry  Service
in fact i am using a queryTask with Geometry Service to perform an intersect request beetwen two(2) Geometry (a polygon and multipoint).
Here is the code ,i use :
   GeometryService _geometryTask;
_geometryTask = new GeometryService("http://www.geomatic.ma/arcgis/rest/services/Utilities/Geometry/GeometryServer");
_geometryTask.IntersectCompleted += GeometryService_IntersectCompleted;
_geometryTask.IntersectAsync(Param1, Param2);   where Param 1 is the list of my multi point and Pram2 is the the polygone
void GeometryService_IntersectCompleted(object sender, GraphicsEventArgs e)
               if(e.Results.Count >0){
       // Here are the graphic result from de geometry request
Everything works well but the graphic result from de geometry resquest contains only the Geometry without attribut data or in my case i need the attribute data beacause i have to show its in a datagrid view.
thanks in adavance for any help
