Routing with Barriers - from Silverlight Samples (not working in the application)
1925
06-09-2011 05:45 AM
srikanthpilli
Could you please help me on putting your suggestions as what to do.
I created a new project and I copied the code that is present in the Arc GIS API for Silverlight Samples.
The code that i copied from the samples are "Legend with Templates" & "Routing with Barriers" - here, when I copied the code and replaced the map service in Mainpage.xaml with another rest service --- legend with templates is working perfect, but for the "Route with Barriers"  i am able to add the stop point and barriers - but its not building the path.
Could you please tell me what changes should i do for working it properly. I am also attaching the code files for your reference.
Thanks for viewing the thread.
DominiqueBroux
Esri Frequent Contributor
As your map is not using geographical coordinates, you must set the outspatialreference of the routing task:
if (_stops.Count > 1)
 _routeParams.OutSpatialReference = MyMap.SpatialReference;
 if (_routeTask.IsBusy)
   _routeTask.CancelAsync();
 _routeTask.SolveAsync(_routeParams);
by Anonymous User
Not applicable
Original User: spill002
Thanks a lot for taking someof your precious time from your schedule and helping me.
