Right click on map or arcgistilemapservice layer to get context menu
1030
09-05-2012 07:22 AM
MichaelBlom
Hi there,
I have been able to do this when clicking on a GraphicsLayer, but is there any way to pick up on the right click on the map or on a tiledmapservice layer?  Many thanks if someone can steer me in the right direction.
Mike
deleted-user-ATjHIWsdQYmT
Haven't try this, with the Map but you could add something like this to your XAML:
<esri:Map x:Name="MainMap" ExtentChanged="MainMap_ExtentChanged" Margin="0,52,13,14" Grid.Row="3" IsLogoVisible="False" Grid.Column="2" Background="White">             <toolkit:ContextMenuService.ContextMenu>                 <toolkit:ContextMenu x:Name="Menu2" Loaded="Menu_Loaded">                     <toolkit:MenuItem x:Name="PropCard2" Header="Show Property Card" Click="menuitem_PropCard"/>                     <toolkit:MenuItem x:Name="Zoom2" Header="Zoom To Parcel" Click="menuItem_Zoom"/>                     <!--<toolkit:MenuItem x:Name="Flicker" Header="Flicker Parcel" Click="menuItem_Flicker"/>-->                     <toolkit:MenuItem x:Name="Remove2" Header="Remove Parcel" Click="menuItem_Remove"/>                 </toolkit:ContextMenu>             </toolkit:ContextMenuService.ContextMenu>
You'll obviously need to import the toolkit:
xmlns:toolkit="http://schemas.microsoft.com/winfx/2006/xaml/presentation/toolkit"
